Samsung S6 -Overheating
  • Updated 1 year ago
I have a S6.  It had worked great.  I was down to 63% so I plugged it in and charged it for 45minutes.  I took phone to work and got it out to use and it was really hot.  I could not do anything with the phone...the blue light was on and the Samsung name was fading in and out.  I tried holding the power button to turn it off and NOTHING happened.  After 3 hours, the battery died.  What is going on with the phone?
Photo of mshabley
mshabley
  • 92 Points 75 badge 2x thumb
Posted 1 year ago
Photo of Goran
Goran, Mobile Master
  • 97,308 Points 50k badge 2x thumb
And it stayed very hot? Could be a temporary glitch or it could be a battery issue or a charging issue.
Try charging it again to say 40% and restart it and see what happens. If it'll cool down or what. I've had phones get so hot they won't even charge but a restart fixed it. Did you also attempt a forced power down? Volume down + power button at the same time for 10 seconds or until it restarts.
Photo of mshabley
mshabley
It stayed very hot until the battery died.  I didn't try the forced power down because I didn't know about that.  I will try to remember that if it happens again.  Thanks for that tip.  Once I got home, I charged the phone to 20% and it seems to be fine....I hope that it was just a fluke.
Photo of Goran
Just keep an eye on it for the next while that it doesn't stay hot and unresponsive. The force restart should definitely help you out if it does. I assume that your phone is over a year old now?
Photo of mshabley
mshabley
I just got it in March.
Photo of Goran
Alright if it keeps up then it would be good idea to use the warranty to get it fixed.
