Samsung S6 Edge - Screen Burn-In
Hi,
I noticed that my screen has a burn-in. The notification bar is much brighter and I have now rectangles that I can see with a white or gray screen. I use my phone quite heavly per day (around 6 hrs screen on).
Is it covered on manufacturer warranty? How long is the repair?
I got so many phones and I never had a burn in. (previously had the Note 4)
Thanks!
Photo of Kevin
Kevin
Posted 3 years ago
Amoled screens can have this issue.
I've never tried it but I found this app that may help.
https://play.google.com/store/apps/de...
Photo of Kevin
Kevin
You are burning the unaffected part (status bar) to make it even. Doesn't really fix the issue, just evens the defect out...
Yup, there isn't a fix. It's a thing that can happen to Amoled panels.
Photo of Robert
Robert, Mobile Master
  • 106,468 Points 100k badge 2x thumb
Wouldn't it be covered by the warranty?
Photo of Kevin
Kevin
Thats what I'm asking Robert! :)
Photo of Mitchell Palmater
Mitchell Palmater
  • 12,996 Points 10k badge 2x thumb
A quick google showed that everyone else had no problem getting a replacement through their respective warranties.
It's not physical damage or water damage.
Just bring it in I would say,
