Samsung S5 SM-G900F with Koode LTE?
Hi,
I recently bought a S5 model SM-G900F and according to the specs it supports 1700/2100 bands.................but my lte speed on my phone seems slow only topping 5mbps.
Network/Bearer
2G GSM
B8 (GSM 850 MHz), B10 (E-GSM 900 MHz), B13 (DCS 1800 MHz), B14 (PCS 1900 MHz)
3G UMTS
B1 (IMT 2100 MHz), B2 (PCS 1900 MHz), B4 (AWS), B5 (US 850 MHz Cellular)
4G LTE
B1 (2100), B2 (1900), B3 (1800), B4 (1700AWS), B5 (850), B7 (2600), B8 (900), B17 (700)
Thanks
Photo of Brandon Gee
Brandon Gee
  • 222 Points 100 badge 2x thumb
Posted 3 years ago
Does the device indicate an LTE signal?
Settings, connection, mobile networks, network type. Should be lte,wcdma,GSM auto
Brandon Gee
well its only indicating a H+ which i think H+ = lte since its a international phone.
and it is set to lte,wcdma,gsm auto.
According to gsmarena.com, the G900F is missing the 1700mhz LTE band. That would explain why you're not seeing LTE
Brandon Gee
Ya I looked that up just now, false advertising on the ncix.com site(which I bought from).
Same information found here: http://www.gsmarc.com/samsung/galaxy-s5/
You have grounds to get your money back for the mistake if you can't live with the speeds. Good luck fighting them.
Brandon Gee
Thanks
Photo of BobTheElectrician
BobTheElectrician
  • 61,736 Points 50k badge 2x thumb
When in doubt, choose a model for Canada or at least AT&T.
Amazing.
