Samsung S4 mini not charging
My Samsung S4 mini is not charging. At home I only have 1 cord, tried two different electrical outlets. Plugged in over nite, nada. Brought the phone and my cord in from my car, plugged in here at work for over 5 hours and still no charge. Thoughts? The phone acknowledges that it's plugged into the charger, but it's not charging at all. I can turn my phone on while it's plugged in. Once it's unplugged, the phone shuts down.
Photo of Danielle Baragar
Danielle Baragar
  • 150 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Ahmad
Ahmad
I recommend using another usb cable/charger. It sounds like the one you're using is defective.
Danielle Baragar
I've used two different cables.
Danielle Baragar
I haven't had an issue charging previously. I just charged my phone Sunday nite, with the cable provided to me when I purchased my phone, and everything was fine. I have used the second cable as well, with no problems. Is it normal for cables to all of a sudden stop working?
Photo of Dennis
Dennis, Mobile Master
  • 196,890 Points 100k badge 2x thumb
Remove your battery and make sure all the contacts are clean and connecting properly.
If that doesnt solve it then it is a battery issue
Photo of BobTheElectrician
BobTheElectrician
  • 67,716 Points 50k badge 2x thumb
You can download a Battery Monitor application from Google Play to confirm the condition of the battery if you can get the phone going long enough.
Charger block available pretty cheap at any dollar store. Worth a try. That phone is not cheap to replace if out-of-warranty.
Danielle Baragar
ummm, one thing. my screen is busted as it was dropped on gravel a few months ago. I have not been able to afford fixing it. Will taking off my otter case make the screen disintegrate to nothing?
Photo of Dennis
  • 196,772 Points 100k badge 2x thumb
Probably not likely.
THen your battery must be shot
Danielle Baragar
Thanks for your help Dennis. Can you tell me if it will be under warranty? I think I'm coming up to one year at the end of March. I saw somewhere else in the community that warranty is one year.
Photo of Dennis
Yes warranty is one year.
The issue it that with a cracked screen, Samsung may say all issue were the result of physical damage. But it doesnt hurt to try
Danielle Baragar
a friend mentioned that as well. But, I broke the screen last summer and I have had no issues with charging until now (HONEST!)
Photo of Dennis
It would be up to Samsung
