SAMSUNG GALAXY W SM-T255S with Koodo LTE
  • Updated 2 years ago
Hello,
Can someone please help me with this phone, SAMSUNG GALAXY W SM-T255S?
I having problem to make it work with LTE.
It does connect to LTE (I can see LTE display on top right corner) but no network connection (can't browse internet).
Here is the network info:
3G bands     HSDPA 850 / 1900 / 2100
4G bands     LTE band 1(2100), 3(1800), 5(850), 7(2600)
Speed     HSPA, LTE-A
Thank you,
Photo of Phong Ta
Phong Ta
  • 152 Points 100 badge 2x thumb
Posted 2 years ago
Photo of rikkster
rikkster, Mobile Master
  • 67,080 Points 50k badge 2x thumb
The phone needs to have Band 4 (1700/2100 MHz) for LTE to work with Koodo. Band 4 is missing from your phone.
Photo of Phong Ta
Phong Ta
Are you saying that this phone will not work with Koodo LTE?
From what I can see here it has LTE band 1(2100), 3(1800), 5(850), 7(2600).
It does not have Band 4 1700/2100 MHz.
It does connect to LTE since I could see the LTE display on the top right, then it should work, correct?
Thank you for your reply.
Photo of Phong Ta
Phong Ta
Yes, Band 4 is not supported.
I was hoping it would work since it could connect to LTE network.
Too bad.. I really like this phone :(
Thank you for your time, rikkster.
Photo of rikkster
You're welcome, Phong Ta. Unfortunately, the LTE frequencies listed are for another country, presumably China. LTE frequencies there are not compatible with Koodo's LTE frequencies here.
Photo of Phong Ta
Phong Ta
I got this phone from South Korea.
It is great for reading.
Photo of Phong Ta
Phong Ta
Does anybody know how to "add" band 4 to this phone?
Thz
Photo of Chadwick
Chadwick, Mobile Master
  • 33,072 Points 20k badge 2x thumb
IT cant be added. The phone comes capable on certain networks. If it doesnt have it built in., you will need a new phone. Also , just because it shows LTE< doesnt mean you will be on it and getting signal.
Photo of Phong Ta
Phong Ta
Thank you
