Samsung Galaxy S5 "unregistered SIM" problem
  • Updated 1 month ago
I have had my Samsung Galaxy S5 for 6 months and it has worked fine. Just yesterday, I noticed the "no service" notification and there is a note at the bottom of the screen that says "unregistered SIM". I have not changed anything in the last few days. How did this happen and how do I fix it?
Photo of Judy Miller
Judy Miller
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Chris Petersens
Chris Petersens
  • 47,246 Points 20k badge 2x thumb
Your SIM card connections might have been compromised. It happens sometime. Take out the battery the SIM card and re assemble. May switch phone to airplane mode and back. If that doesn't help you may need another SIM card.
Judy Miller
Thank you! I turned my phone off overnight and it seems to be working fine so far today. I guess some little gremlins got in with my SIM card and now they've left...
Photo of Robert
Robert, Mobile Master
  • 101,020 Points 100k badge 2x thumb
To make sure it doesn't happen again, remove et re-insert the SIM card correctly
  • 60 Points
I switched to Airplane mode and back and it worked again!
