Samsung Galaxy s4 won't stay connected to data
my phone won't stay connected to Koodo. It usually switches to emergency calls only. And then I have to go into settings to reconnect to the network any way to stop this? Its a Galaxy S4 the image shows what it does very frustrating .
Photo of Hillary Grant
Hillary Grant
  • it frustrates me a lot.
Posted 3 years ago
Photo of Daniel Kim
Daniel Kim, Mobile Master
Hi Hilary, how is the coverage in your area? This is a link to a coverage map http://help.koodomobile.com/coverage-...
Hillary Grant
I live not far from the US border around the 95 area.
Hillary Grant
In New Brunswick... it wont attach the screen shot
Hillary Grant
it does it more when I am trying to text someone... If I'm not texting it will stay on Koodo which is weird and annoying
Photo of Daniel Kim
Have you tried manually selecting koodo/telus? Usually if you live near the US border, that's a good thing to do rather than have your phone search for carriers automatically.
Photo of BobTheElectrician
BobTheElectrician
  • 67,578 Points 50k badge 2x thumb
Phone with post-paid SIM will pick up the strongest tower serviced by Koodo or authorized roaming partners, including US. Do you often get that annoying text message that tells you about marvellous US roaming near the border? That's courtesy of the CRTC.
Folks in our area (near Qc 55 / US 91 border) get used to flipping the Network setting to Koodo only to avoid accidental roaming if a US tower has a stronger signal than Koodo in our area.
BobTheElectrician
You might also want to check signal strength. Bars on the phone are just barely decorations. Download from Google Play:
https://play.google.com/store/apps/de...
or something similar. Gives fairly instantaneous readings for voice and data in -dBm units. As long as you show less than 100 -dBm, you should be able to communicate. If you can send yourself a text and receive it promptly, then the network connection is working.
Even in areas that have good coverage, it’s not uncommon to have dead zones. Stay away from large metallic objects such as wrought iron railings and open any metallic window blinds.
Had a local problem with trees/hills/valleys galore at home in a rural area and was able to find a “hot spot” where everything works. Even re-orienting the phone while looking at the meter made a big difference.
There are sister apps that will do the same for WiFi coverage as well.
Okay Bob, I know you're in the Estrie.
Stanstead? AC? Beebe? I'm in Magog
Find me know FB, we should meet up.
