samsung galaxy s captivate. will it work with koodo?
its unlocked but dont work. it recognizes the sim card and phone number
Photo of Doug Knox
Doug Knox
Posted 3 years ago
Photo of HippieLongstocking
  • 24,720 Points 20k badge 2x thumb
Hey Doug!
check out this link below, it will let you know if it will work with koodo or not and if its been reported as lost or stolen.
Photo of BobTheElectrician
  • 57,518 Points 50k badge 2x thumb
If the phone is indeed the AT&T version of the Galaxy S, and is unlocked and not blacklisted, it should work, up to 3G and partially on LTE.
If your only problem is data, you may need to fix the APN. Do a search for APN in the search topics box above, and you will get the correct values.
