Samsung Galaxy Ace II x shuts down with battery still charged 95%
I got my Samsung Galaxy Ace 2 x about 3 years ago. Few months after purchase the phone wouldn't charge. I sent it back to be fixed on warranty. Never had any problems with it since until recently. The shuts down with still a lot of juice in the battery. When I press power button it shows the battery's empty. Only when I plug it the charger and press the power button again it shows the battery is almost fully charged and powers up. Now I have to have the charger plugged in so i can quickly connected to it when some one calls or sends a text. I'm not sure if it's the battery or the phone. I was going to do factory reset on it but I'm afraid it might make things even worse. Does anybody know how to fix that problem?
Photo of Woiciech Waclawski
Woiciech Waclawski
Posted 3 years ago
Photo of rikkster
rikkster, Mobile Master
The phone is giving a false battery reading. If you're not able to power the phone on without the charger, that's usually an indication that the battery can no longer hold a charge and needs to be replaced. You can order a replacement battery for your Ace 2x from eBay Canada.
http://www.ebay.ca/itm/like/331513815...
