Samsung Galaxy Ace 2x Power Button Has Failed
I have a Samsung Galaxy Ace 2x (GT-7560M) and some issues. A few days ago I noticed that the power/lock button on the side is not responding anymore. I looked up a couple things and tried pulling out the battery and re-inserting, but the power button will not do anything. The only way I can boot up my device is to pull the battery, plug in the powered USB, then re-insert the battery. The power button still will not respond however.
I have had issues with this model before and got it replaced about 5 or 6 months ago for similar issues with the either the home or power buttons. Now I have a feeling that this is just a faulty device in all.
Are these known issues with this model of phone and if so are there any fixes available?
Photo of Jacques Manseau
Jacques Manseau
Photo of Daniel Kim
Daniel Kim, Mobile Master
I'm not sure if the power button is a known issue but the Ace 2x is known to have issues Jacques. Is the phone still under warranty? You could try getting it repaired again. But in all honesty, a new device will make your life much easier, I recommend a moto g or a N5.
Note: If you do decide to upgrade, you'll have to pay off your tab if you have one before doing so.
Jacques Manseau
Thanks for the feedback. Yes, I am thinking an upgrade might be better for me than trying again with this same phone.
