samsung galaxy 5 gets really hot and battery dies 3 times a day .. phone purchased Feb 5 2016 .. today is feb 17, 2017 .... what can i do
  • Updated 1 year ago
my samsung galaxy 5 gets really hot and battery dies 3 times a day ... phone purchased Feb 5 2016 ... today is feb 17, 2017 .... what can i do
Photo of Linda Short
Linda Short
  • 160 Points 100 badge 2x thumb
  • pissed
Posted 1 year ago
Photo of Allan
Allan, Mobile Master
  • 62,674 Points 50k badge 2x thumb
Unfortunately you are no longer eligible for the manufacturers warranty. Your phone most likely gets hot due to a app that requires heavy usage from the phone. I would play around with the apps and figure out what app you are using when the phone gets hot and then delete that app from your phone.
Photo of Allan
Booting into safe mode is a good way to test if an app is causing the overeheating. Make sure after booting into safe mode you stay in it for about 24 hours to allow time to solve the problem. If the phone doesn't overheat than start deleting apps that you think may be causing it. If it does overheat still than you will need to take it in for repairs.
Here is how to boot into safe mode
1) Turn the device off.
2) Press and hold the Power key.
3) When 'Samsung Galaxy S5' appears on the screen, release the Power key.
4) Immediately after releasing the Power key, press and hold the Volume down key.
5) Continue to hold the Volume down key until the device finishes restarting.
6) Safe mode will display in the bottom left corner of the screen.
7) Release the Volume down key when you see Safe Mode.
Photo of Robert
Robert, Mobile Master
  • 107,362 Points 100k badge 2x thumb
Hello Linda.
I'd suggest to call Koodo or Samsung ASAP or do a factory reset to see if the problem is solved.
Linda Short
none of that helped ... it started to happen 4 days ago ... just like an electronic device. As soon as the warranty is up it screws up.
My koodo tab is only half way and I'm on Disability.
I had a Blackberry before and it lasted years.
I was warned to stay away from Samsung.
I'm extremely upset with this.
Photo of Allan
Did you try the steps i mentioned above? This should fix your phone Linda.
Photo of Ivan
Ivan, Mobile Master
It could be your battery, which isn't that expensive to replace.
