Samsung G3 and data usage
  • 2
I have a Samsung G3, and my plan covers 300 mb per month. I reached my maximum, and I don't wanna be charged for those extra mb. Is there any setting on my phone where I can automatically turn off the extra mb and be allowed to use ONLY my 300 mb?
Photo of Ronaldo Natali
Ronaldo Natali
  • 2
Photo of Andy Zhong
Andy Zhong
  • 846 Points 500 badge 2x thumb
I don't believe there is a way on koodo's end to do on that but on ur phone u can set ur data usage tongive u a warning when ur close to ur 300mb usage and it disables ur data usage when it hits the limit u set it to. Just make sure u check the billing cycle its set to
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 202,866 Points 100k badge 2x thumb
Sorry for saying the same thing I fell asleep while typing when the question was unanswered and then finished and posted when I woke up again. My bad
  • 203,666 Points 100k badge 2x thumb
Yes go into the settings menu and under "Data usage" you will see a grid, there's 2 bars a warning and a shut off bar. Just raise or lower the shut off bar (which is red I believe) to 300mb and the data connection will automatically disable your data connection when you've reached your max you've set. Keep in mind that this counter isn't 100% accurate as it counts data used to send and receive mms (pictures messages) which Koodo doesnt count since your not charged for that data used.
Photo of Dennis
Dennis, Mobile Master
  • 196,568 Points 100k badge 2x thumb
Settings >wireless&networks>data usage
Set data limit
You can set your billing cycle and your MB limit. I would set it at 250mb just to be safe.
Ronaldo Natali
Thanks a lot, guys. Really appreciated it!
