Samsumg Galaxy X2 INTERNET CONNECTION PROBLEM FIX>>>>>
  • Idea
  • Updated 6 years ago
  • Not Planned
follow the instructions
To fix the Samsung Galaxy S2 data connection, you can following this steps:
Step 1: Press menu then settings >Wifi network>Mobile networks >Access Point Names.
Step 2: Got back one page and pick Network operators until the phone finds Koodo select.
Step 3: Switch Network mode to GSM.
dont forget to restart your phone after these settings.....
Photo of Harry
Harry
  • 300 Points 250 badge 2x thumb
  • excited
Posted 6 years ago
Photo of Mark
Mark
  • 3,016 Points 3k badge 2x thumb
Your instructions make no sense.
Nothing lines up with an actual S2X.
Menu -> Settings -> More... -> Mobile Networks
By default there should only be one entry under access point names sp.koodo.com
As well you will want to use GSM/HSPA(auto mode), as flipping it to just GSM would neuteur your HSPA or HSPA+ connection.
Can't recall seeing anyone on here having issue with the S2X...
Photo of Harry
Harry
i can post for you phone thts for X2
Photo of Mark
Mark
There is no Galaxy X2...
Photo of Harry
Harry
For now try Updating firmware and reset it, i havent got any problem with s2x yet but i ll find a fix if you do have it.
Photo of Harry
Harry
sorry typing mistake it was s2 not x2
i will post soon for s2x
