S.O.S In need of some help please
I own a Samsung Galaxy ace 2 and i forgot my number pin password, and i have no other options for unlocking it! So is there a way that i can unlock it? if not can i take it to where i purchased my phone and get them to unlock it? how much would it coast?
Photo of Christtnne Coulombe
Christtnne Coulombe
  • frustrated
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
If there is no other way to unlock the device, it would need to be factory reset.
Photo of Brittany Behenna
Brittany Behenna
  • 310 Points 250 badge 2x thumb
If you don't remember the pin password to unlock your phone to use it, I believe it will eventually ask you for you google email address and password. Enter that in and it should work. If not, then yes a factory reset is the only other option, which will whipe everything on your phone.
Photo of tlee1973
tlee1973
  • 634 Points 500 badge 2x thumb
Also to factory reset your phone, most android devices can be done by holding a series of buttons at the same time, usually power volume down and home button, this will do a factory reset, however you will loose all info so just keep that in mind, once you get your phone working again, try to make sure your info is backed up to your google account by going into accounts and sync and clicking on your gmail and you should be able to sync everything there. You can also look on youtube for a video on how to do it for your specific phone.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 140,052 Points 100k badge 2x thumb
If anyone can find a way to boot a galaxy ace 2x into recovery mode (verified with a phone in your hands, not a link to an internet post) please post it. I have yet to get it to work on this model of phone.
Zaphod Beeblebrox
This took me a few tries to finally get it.
Press and hold the middle of the volume button. You will feel a "double click," press and hold the home button then press and hold the power button untill you see the model number of the phone show as it usually would when you power up the phone normally
You will see the Andoird guy show up and then a menu. press volume buttons to go up and down. Wipe data/factory reset, then Yes. After that, select "reboot system now."
Muchos gracias. Could have sworn I tried that. Guess the phone itself is more finicky about it than most.
Zaphod Beeblebrox
Very finicky. Feelz the double clicking I mentioned and it SHOULD be downhill from there.
