S7 Edge - Black lines appeared on my screen - HELP!
  • Updated 1 year ago
This issue just started last night. Not sure what caused it, just seems to have appeared out of nowhere.
My screen has 3-4 black translucent lines. They get bigger / smaller when I adjust the brightness. This is really frustrating, I havent even had the phone for 1 year, and I baby it. Haven't dropped it once and it has a good case on it. Here's a video showing the issue - https://www.youtube.com/watch?v=FjvnL2mckv4
Has anyone else experienced this? How can I fix it?
I bought my phone online from Koodo directly for what its worth.
Photo of CWC
  • 200 Points 100 badge 2x thumb
Posted 1 year ago
Photo of Dennis
Dennis, Mobile Master
  • 178,354 Points 100k badge 2x thumb
You will have to go through the warranty process.  Make sure you do that before your 1 year is up
I personally have not experienced the translucent lines you are experiencing,
Photo of Allan
Allan, Mobile Master
  • 50,858 Points 50k badge 2x thumb
There is a temporary fix that has worked for some people. Go to the brightness settings, turn on auto brightness then drag the slider all the way to the right.
If your phone is within 15 days of purchase you can return it for a new phone.
If it is within 1 year then you can contact Samsung to get instructions on a replacement screen for your phone.
  • 203,644 Points 100k badge 2x thumb
If you got the phone from Koodo, Koodo can assist you to get warranty service and a possible loaner device. I'd go with the warranty process.
