s5 neo dead battery 4 months old major charging issues
  • Updated 12 months ago
s5 neo 4 months old. heat up doesnt charge properly battery totally dead now. tried multiple chargers factory resest phone is junk. no physical damage. can i reurn this phone and have my tab cleared or exchange it
Photo of Simon Hoogenboom
Simon Hoogenboom
  • 82 Points 75 badge 2x thumb
  • ripped off
Posted 12 months ago
Photo of Robert
Robert, Mobile Master
  • 100,908 Points 100k badge 2x thumb
Hello Simon,
It's not possible to return the phone, the only thing you can do is to send it for reparation by pressing yourself to a Koodo store.
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 192,542 Points 100k badge 2x thumb
Look at the battery and if it s swollen / bulged out at all then make sure you do not try to charge it at all and follow Roberts suggestion asap as the battery could explode or catch fire.
Photo of Allan
Allan, Mobile Master
  • 50,028 Points 50k badge 2x thumb
As well, using chargers other than the ones given by the manufacturer may harm your battery so either avoid using them or make sure they are outputting the right voltage, amperage, etc. to your device
Simon Hoogenboom
Thanks for the replies. I will try to get to a store to see if they will repair. I have many brand name samsung chargers tried them all. Hard resest sometimes it would start to charge. Totally dead now. Lucky my old telus phone worked with the sim card so I have something. Just dont wanna pay for the next 20 months on a dead phone lol
Photo of Ivan
Ivan, Mobile Master
  • 95,438 Points 50k badge 2x thumb
Depending on the age of your old phone, you may be interested in getting a loaner phone from the Koodo location when you drop off your phone for service.
Photo of rikkster
rikkster, Mobile Master
  • 66,272 Points 50k badge 2x thumb
How about a new battery? The battery is removable. If there's nothing wrong with the phone, this might be an option. Shop around, the link below is only a suggestion.
