s3 wont charge
hi
samsung s3 wont charge, its fine charging via usb to computer and 12v but not in an evdryday plug
Photo of Jon Somers
Jon Somers
  • sad
Photo of MatB
MatB
  • 32,478 Points 20k badge 2x thumb
Check different power outlet, check different charger, borrow same battery from some one you know, visit Koodo shop for battery/phone/charger testing. if 14 days MBG or more than 14 dyas they will help you
Are you using the original wall charger to charge it. Different wall chargers may all be 5v out but the Amperage output may be different and that could be your problem. Check eBay for the original charger specs and compare your adapter to the original. If the amps are lower you'll have issues.
