S2x gps issue: Poor signal
my samsung galaxy s2x always has poor gps signal. Whys that? Is it a faulty phone? I purchased this two days ago and i was hoping to use it for gps purposes. Please tell me theres a way around this problem!
Photo of RobS
RobS
  • 286 Points 250 badge 2x thumb
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 203,130 Points 100k badge 2x thumb
Try doing a factory reset, if that does nothing then you might want to go back & exchange it considering GPS is something very important to you.
Photo of RobS
RobS
Thank you, im going to trying installing those apps that rikkster has recommended to me. If problem persists, i will return it to koodo for another one.
Photo of rikkster
rikkster, Mobile Master
  • 68,238 Points 50k badge 2x thumb
Couple of free apps on Google Play can speed up gps satellite acquisition, I'm using a paid version of Sygic GPS Navigation on the S2x without issue and without using data. I've also run Sygic along with GPS Fix and GPS Status on my HTC Raider, for close to a year. I've found the S2x and the HTC needed a clear view of the sky while running these fixes. After that, both devices performed perfectly.
GPS Fix
https://play.google.com/store/apps/de...
GPS Status
https://play.google.com/store/apps/de....
Photo of RobS
RobS
Im currently installing it, thank you your response was helpful.
