Rogers Galaxy S5 Help
Hello, want to ask for some advice. Have a chance to buy a gently (4 weeks) used rogers galaxy s5. price is very good. Unlocking looks very simple with these phones (put in a new sim and enter a code).
Since I don't have the phone I can't get the IMEI to use the tool to see if it is compatible with koodo.
Can anyone comment if it will work? Also any concerns about buying second hand aside from the obvious wear and tear concerns? Thanks!
Chris
Photo of Chris Furey
Chris Furey
  • 196 Points 100 badge 2x thumb
Photo of John Burke
John Burke, Mobile Master
It should work on Koodo's network.
Just make sure you get it unlocked.
Photo of Dennis
Dennis, Mobile Master
  • 196,652 Points 100k badge 2x thumb
Or koodo can unlock it if you are signing up
Photo of Jonathan I
Jonathan I, Mobile Master
Be sure to look here first: www.protectyourdata.ca
