Rogers home phone unable to call Koodo home phone.
  • Updated 1 month ago
I have a Rogers home phone and I am unable to call a relative's koodo home phone. The mesage says the number is long distance and tells me to press 1 before the number. When I press 1 before the number, the message tells me the number is not long distance and does not require 1 before the number. We can receive phone calls from the koodo line with no issues.
Photo of Kimbees
Posted 1 month ago
Photo of David
David, Mobile Master
  • 83,352 Points 50k badge 2x thumb
That's on Rogers!  Connect with them to see if they have a solution!
Photo of Barb Scott
Barb Scott
  • 260 Points 250 badge 2x thumb
I am not sure did you call Rogers about this . If you had a Koodo wireless you would be able to call Rogers. get the Koodo person to try calling you without dialing 1 bet they have no problem
Photo of BobTheElectrician
  • 57,352 Points 50k badge 2x thumb
No guarantee, but try dialing *671xxxyyyyyyy where xxx is the area code and yyyyyyy the 7-digit local number.
The *67 prefix (block caller id info for this call) sometimes clears problems over interpretation of where the call is originating. I have to occasionally use it when calling from my VoIP service if I can't successfully connect to 1-800 numbers.
