Roaming with Samsung
Then I travel to the US with a roaming add on. I have to reset my phone all the time to get it to work. When I answer the phone with out a reset I can not understand what they are saying. I have a Samsung sgh-t989d
Photo of Dale Scott
Dale Scott
Posted 3 years ago
Photo of Khaleila
  • 4,102 Points 4k badge 2x thumb
Hey Dale,
When you say reset, do you mean you have to do a factory reset of the phone?
  • 203,644 Points 100k badge 2x thumb
Yeah the S2x and AT&T dont like eachother. I had the same issue. Only fix is to power it off and remove the battery and sim. Then replace the sim and battery. Weird but thats the way it is.
