Roaming
  • 2
  • Updated 2 years ago
  • (Edited)
I arrived to Italy a few hours ago and still my Motorola moto g4 can't connect to any Italian networks and keep saying "emergency calls only". Do you guys know what's going on?
Photo of Gabriele Pucci
Gabriele Pucci
  • confused
Posted 2 years ago
  • 2
Photo of Goran
Goran, Mobile Master
  • 97,308 Points 50k badge 2x thumb
Go into networks and go into manual selection and let the list populate after 1-2 minutes. What do you see? Hav you restarted your phone yet?
Gabriele Pucci
Yeah I did everything you said, but everytime I try to connect to one of these networks it says impossible and will try later. I also restarted my phone a couple of times.
Photo of Goran
Oh also did you enable international roaming with the zero dollar add-ons in self-serve ? You need those on in order to roam internationally. Pay-per-use international long distances international voice roaming, and International Data Roaming for data.
Also I'd suggest picking up a local Sim as it's almost always significantly cheaper.
Gabriele Pucci
How do you enable that zero dollar add one? On my personal Koodo page? And yes I've already a local sim cause I'm actually from Italy (I live in Canada though) but I still need to roam for some business purposes. Thank you so much for your help
Photo of Robert
Robert, Mobile Master
  • 106,940 Points 100k badge 2x thumb
Hello Gabriele.
Here's how to add the free international roaming packages. There's two of them :
Connect to sell serve and go to your add-ons
Click to change the add-ons
Search for 1) International Voice Roaming and 2) International Data Roaming
Photo of Goran
Another option, although I don't know if it needs to specifically be your current number for business purposes is to use Fongo or Textnow where you will receive a Canadian phone number and you can make free calls over cellular data or wi-fi. Fongo says their bitrate is 2 minutes per MB.
Photo of Bernard
Bernard, Official Rep
  • 80,864 Points 50k badge 2x thumb
@Gabriele You account has all the right services, including the zero dollar add-ons. I'm thinking it's your phone and may be restarting would help as long as roming is turned on in your phone's settings.
