roaming
  • Updated 7 months ago
how much will it cost per minute to make a call while I'm in the us to canada and us numbers?
Photo of Manda De
Manda De
Posted 3 years ago
Photo of Erwin
Erwin
  • 23,546 Points 20k badge 2x thumb
Hi Manda,
If you got a US roaming plan while you are in the USA, calling is unlimited from USA to Canada. As well as text messages. If you are in Canada, you can add Unlimited US Calling for $10/month. Texting is also unlimited globally while you are in Canada.
Photo of Kelly G
Kelly G
  • 90 Points 75 badge 2x thumb
I don't think this is correct. Maybe it was 3 years ago when the question was first asked.
My son bought the 3ALL roaming add on which gives unlimited minutes for calls made to numbers within the US (see screenshot of add on summary). But it doesn't indicate that calls to Canada are included. I think you will pay $1.50/minute back to Canada even with the add-on. I've been searching all over Koodo's web site trying to find the answer to this question. Ridiculous that they make it so hard to find the answer.
Photo of David
David, Mobile Master
  • 89,116 Points 50k badge 2x thumb
See comment below.
Photo of Alex H
Alex H
  • 448 Points 250 badge 2x thumb
If you don't grab a roaming add-on, roaming pay-per-use rates in the US are $1.50/minute for calls within the US and back to Canada.
Photo of Kelly G
Kelly G
I don't think this is correct. Maybe it was 3 years ago when the question was first asked. My son bought the 3ALL roaming add on which gives unlimited minutes for calls made to numbers within the US (see screenshot of add on summary). But it doesn't indicate that calls to Canada are included. I think you will still pay $1.50/minute back to Canada. I've been searching all over Koodo's web site trying to find the answer to this question. Ridiculous that they make it so hard to find the answer.
Photo of David
Scrolling to the bottom of the page containing the image you posted finds this:
