Roaming
  • Updated 1 year ago
I am out of Canada and had some missed calls. People left messages. What will be the charges if I listen to my messages on raoming? Will it be same as the roaming charges if I make a call or different?
Photo of Asif
Asif
Posted 1 year ago
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 142,616 Points 100k badge 2x thumb
Charges would be the same as if you placed a call. You bang check your messages from another line by calling your number and pressing * when your voicemail picks up. Don't forget to dial the +1 in front of your number if you're calling from abroad.
Photo of titaniumtux
titaniumtux
  • 12,952 Points 10k badge 2x thumb
^^Agreed with Timo.
@OP if you're in the US, you can call your Koodo cell number via Google Hangouts Dialer, anywhere else grab the MagicApp or Freetone and call your Koodo cell number free over wifi, then follow Timo's steps.
