Roaming Not Working - Urgent!
  • Updated 5 months ago
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: 1866
I have the daily roaming package for use while I am in Mexico. My texts and data are working, but when I go to make a long distance call, it says 'we're sorry you can not make Int' calls at this time.' I am here working and need to make Int' calls urgently. And I am also paying daily for the service! Please help ASAP.
I have also emailed, since I can't call Koodo. It stupidly tells me to call *611 but of course that is an international call, so I get the same message!
I have an unlocked LGg4
Photo of alexis
alexis
Posted 5 months ago
Photo of Dinh
Dinh, Mobile Master
  • 41,532 Points 20k badge 2x thumb
Hi Alexis,
I would try to restart the phone and reset the network settings. Hopefully the reset will help.
What add-ons did you have on your account? easyroam and international voice roaming?
Photo of alexis
alexis
Reset my networking settings to what? Yes, I have easyroam and inter'l voice roaming according to my self-serve. Althougth they have a fee of $0 beside them. However, my data and text are working so I must have them
Photo of Dinh
Dinh, Mobile Master
Alexis
Reset settings can be done with your phone, it will try to refresh the parameters of the network. I would try to restart the phone also.
As you mentioned, you had everything to roam, so the issue could be some roaming glitches, which we didn't know where yet.
Photo of alexis
alexis
HI, sorry, not sure which settings you are referring to to re-set? I have restarted my phone numerous times. It's been 3 days...And there is no way to contact Koodo which is ridiculous.
Photo of Dinh
Dinh, Mobile Master
@Alexis
To reset: From a Home screen, navigate: Apps  > Settings  > Backup & reset. Tap Network settings reset.  Tap Reset Settings.
You could try to contact Koodo through the number 1 (866) 995-6636 from skype or any voiip program, or sending message to their facebook, if you can not call 611.
Photo of Dennis
Dennis, Mobile Master
  • 196,006 Points 100k badge 2x thumb
Does it mention anything about call barring?
Photo of Rey Lopez
Rey Lopez
In Mexico with unlock phone what you need is a Telcel Sim card and an unlimited package that hive you inlimits talk sns and 1-5 GB data for less than 40 CDN a month.
Photo of alexis
alexis
Iknow I can get that, but I need my Canadian # and am already paying for Koodo's roaming package. Can't I use Koodo with a roaming package??
Photo of Robert
Robert, Mobile Master
  • 106,774 Points 100k badge 2x thumb
Yes you can totally use Koodo as roaming package. Did the reset networks settings work?
