Roaming not working in HK
  • Updated 3 weeks ago
No one can call me from Toronto but my text and data work well. How this can be happened?
Photo of david yang
david yang
  • 280 Points 250 badge 2x thumb
Posted 3 weeks ago
Photo of david yang
david yang
HK means Hongkong LoL
Photo of Mats
Mats
  • 21,750 Points 20k badge 2x thumb
Can you call from your phone or is it just receiving calls that is the problem? What is happening when they are trying to call you? Are they dialing properly? The site below might help.
https://www.howtocallabroad.com/hong-...
Photo of Dinh
Dinh, Mobile Master
  • 41,904 Points 20k badge 2x thumb
hi David,
Which local carrier are you on? Have you tried to switch to another carrier and see if it helps? I would also try to restart the phone.
Photo of david yang
david yang
I have no idea. And I did received a call when I was in Macau. I also tried switch carrier but not successful. I would expect the easy roaming is really easy.
Photo of Dinh
Dinh, Mobile Master
  • 41,784 Points 20k badge 2x thumb
Have you tried to call a local number? and the local people can call you?
Easyroam is like an accounting code, with that Koodo know how to charge people. Roaming is the same like before, and it is controlled partly by local roaming partners also. That was why I asked if you can switch to another carrier. Which phone are you using?
Photo of Robert
Robert, Mobile Master
  • 107,280 Points 100k badge 2x thumb
When you say they can't call you, what does that mean? They hear the ringing sound but you don't? Or they simply can't connect the call?
Photo of david yang
david yang
They had the message: this phone number is not in service, but my text and data worked fine. I am in mainland China now and everything is fine.
Photo of Dennis
Dennis, Mobile Master
  • 196,120 Points 100k badge 2x thumb
If you are headng back to HK and this issue happens again you will need to contact Koodo.  A private message to Facebook would be the best option, but dont expect a response until after the long weekend
