Roaming
I just bought the Mexico text add-on. Do I need to keep my roaming on to use this feature?
Photo of Debbie Delmore Russell
Posted 3 years ago
Photo of Robert
Robert, Mobile Master
  • 103,734 Points 100k badge 2x thumb
If you chose data with it, then roaming for data should be enabled. If you have no data, the disable roaming. By default, text and voice should be always activated. You can only change for data I believe
