Roaming digital garble noise
I am visiting Houston Texas and have added a roaming package to my phone. I can text and surf the web but I cant make phone calls. It dials and the other phone rings but all I hear is garbles digital noise.
Photo of Jocelyn Remus-Robinson
Posted 3 years ago
Photo of BobTheElectrician
  • 57,040 Points 50k badge 2x thumb
Re-start (power cycle) your phone.
Can you call another local number successfully? Try any pizza joint or retailer.
I have found that sometimes VoIP (Vonage, etc) don't like to play nice with mobile.
  • 203,644 Points 100k badge 2x thumb
I'm going to assume you have a Galaxy s2x
This unit doesn't play well when it's Roaming and there are only two solutions. The hard solution involves rooting the device and flashing the T-Mobile radio.
The easy and temporary solution is to turn it off and remove the battery and sim card for a full minute then reinstall all that and turn it back on..
There's nothing else really you can do for it. It's a quirk of the T989D
