Roaming - Data will not connect
  • Updated 2 years ago
I have an S4. I am currently travelling and added on the travel plan. For the first couple of weeks, the data would turn on when I checked the box to turn it on (I leave the data roaming box checked as well). For the past week and a half, the phone will only connect to the basic network (for phone calls and text). There is an R above the bars, not the normal LTE that shows that data is connected. I'm in a fairly dangerous country by myself and I am quite displeased with the lack of customer service from koodo. Uber is the only safe form of transportation and I am only able to connect if I find WIFI, making me feel very unsafe.
Photo of BGB
BGB
  • 90 Points 75 badge 2x thumb
Posted 2 years ago
Photo of BobTheElectrician
BobTheElectrician
  • 61,606 Points 50k badge 2x thumb
Koodo has to rely on local providers for roaming to work. Some countries have very poor coverage outside of major cities.
If the phone connects to basic voice & txt service, it's not likely Koodo's fault, and your plan is obviously working.
Where are you travelling? Maybe someone in the community has exerience with your locale.
Photo of BGB
BGB
I am in Peru in a major city. Data worked here on my phone 2 weeks ago. It just suddenly stopped. It still works on my classmates phones.
Photo of Daniel
Daniel, Employee
  • 5,702 Points 5k badge 2x thumb
Hi Bridget! I saw that your email was answered by our Email Team. Are you able to use your data correctly now?
Photo of BGB
BGB
Hi Daniel,
I followed the instructions in the email and the data still will not connect. However, I am flying back to Canada tonight. I am hoping that upon my return, the data will automatically start working on the Koodo network. In the event that it is not a roaming issue and it is an issue with the phone not connecting to data, what should my next steps be? Is there a help center in Toronto?
Thanks
BobTheElectrician
Drop into a Koodo store. They should at least be able to check your SIM and phone with working store equipment to help you identify your problem. If it's the SIM, get a new one and your problem is solved.
https://www.koodomobile.com/find-nearest-store
