Roaming Data for More than a month
  • Updated 1 year ago
Canadian travelling in U.S. for 3 mo. Texted 30ALL to get 750 Data, unlimited calls & texts. Went to renew at the end of the month and am told that you can only renew calls and texts, not Data. What??
Photo of Jane Hickson
Jane Hickson
  • 90 Points 75 badge 2x thumb
Posted 1 year ago
Photo of Mathieu
Mathieu, Mobile Master
  • 60,828 Points 50k badge 2x thumb
Hi Jane,
You need to wait for your billing cycle to reset before adding the same add-on again. You can only have 1 of each roaming add-on per period. Wait a couple of days and you should be able to add the same add-on again.
Jane Hickson
Don't think it has anything to do with the billing cycle because the cycle runs from mid-month to mid-month.  The add-on started at the end of the month.  Anyway, are you saying that once the add-on has expired, that I can definitely get 30ALL (data plus calls/texts) again for the following month?
Photo of David
David, Mobile Master
  • 89,034 Points 50k badge 2x thumb
Yes.
Jane Hickson
Great.  Thanks.  Spoke to a rep at Koodo and he said I could not renew the data, just the calls/texts.  Maybe he was confused.
