roaming charges
going to carribean and will be hooking to resort wifi, is there something I have to doso I don't get charged roaming fees on my phone as I have a data plan
Photo of Gina Callander
Gina Callander
  • 72 Points
  • thankful
Posted 3 years ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 193,128 Points 100k badge 2x thumb
If you dont want to use your phone at all other than to hook to wifi the best fail safe method is to simply remove the SIM Card from the phone. If you just don't want to use data then go into the settings menu of the phone and disable your data connection.
