Roaming charges
  • Updated 1 year ago
I purchased the $40 roaming add-on for Cuba where I have 50 outgoing text, 50MB data & 50 mins phone. When I check my "usage"; it doubled up my actual texts messages. When I compare my usage sheet to my actual phone messages going out I have double the number hence an extra roaming charge added to my bill... What is going on there?
Photo of Danielle Langevin
Danielle Langevin
  • 90 Points 75 badge 2x thumb
  • confused
Posted 1 year ago
Photo of Allan
Allan, Mobile Master
  • 62,694 Points 50k badge 2x thumb
When viewing the usage via self serve it will show you the total for incoming and outgoing. Is this what you mean by "doubled up" or when you view the usage you see that your outgoing texts are doubled?
Danielle Langevin
I count only the outgoing as the incoming are free!
Photo of Robert
Robert, Mobile Master
  • 107,422 Points 100k badge 2x thumb
If you send a long text, it might divide in 2 texts. Maybe that's why you see 2x outgoing texts...
Photo of David
David, Mobile Master
  • 93,758 Points 50k badge 2x thumb
Long being more than 140 characters.
Photo of Allan
Actually it depends on what kind of characters you are using. (Emoji's count towards a good chunk, almost 100 characters in my case).
Alphanumeric characters only will let you reach 160 so in most cases you will be able to send 160 characters before creating a new text. Your phone will say right above the send button usually how many characters you have left before a new text message.
Danielle Langevin
I have watched that character count & yes in two occasions I had to send two messages but otherwise the "usage" count on my bill seems to have doubled up the actual amount of texts sent out...
Photo of Allan
You can click View Details on the messages and compare them with you're messages sent to double check this error. If it still appears to be doubled you contact Koodo to review your case and possibly get some credit applied to cover the extra charges. I would suggest contacting them through facebook (https://m.me/Koodo) but you can also call or message through twitter dm.
Danielle Langevin
Thanks Allan, I will contact them!
