Roaming charge
I just added the $30 add on for US Unld min/sms $30 10day . When I make a call to Canada my phone says that there is roaming charges. Why do I get this display when I paid for the add on?
Photo of gglacey
Posted 3 years ago
Photo of Cameron Jones
Cameron Jones
  • 6,960 Points 5k badge 2x thumb
Not sure, best to double check the US roaming package is in effect. Call 611 from your phone to speak to a rep about it.
Photo of Mayumi
Mayumi, Mobile Master
  • 111,398 Points 100k badge 2x thumb
I think that message is already programmed on your phone like when you make long distance calls within Canada( long distance charge may apply...)
Phone doesn't know what plan or add-ons you have that's why you see/hear this message.
Make sure your US roaming package is in effect as Cameron say, and you should be good.
Photo of Dennis
Dennis, Mobile Master
  • 178,354 Points 100k badge 2x thumb
You can log into your self serve anc check your plan & add-ons to confirm you have the roaming package subscribed. If so then dont worry about it.
Also when you subscribed to the add-on you should have gotten a confirmation email.
Photo of Robert
Robert, Mobile Master
  • 101,484 Points 100k badge 2x thumb
Usually this happens when you dind't dial the number proprely so the cellphone redirects the call, therefore warning you that there may be roaming charges. But if you have the add-on there should be no problem!
