Roaming
  • Updated 10 months ago
  • (Edited)
Do I have to still pay roaming charges because my phone is on US tower despite still being in Canada
Photo of Sarah Davill
Sarah Davill
  • confused
Posted 10 months ago
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
Hi Sarah, yes, so you'll have to talk to Koodo about this (*611 from your mobile phone) by either calling or sending them a message over Facebook through a private message.
You'll then have to go into your phones settings menu and select Koodo as the network you want to connect to manually so it doesn't automatically connect to other networks.
To do this go to settings - More - Mobile Networks - Network Operators - Search For Networks and your phone will search for towers in the area which will take a minute to search then a list will come up, select Koodo.
Photo of David
David, Mobile Master
  • 88,962 Points 50k badge 2x thumb
You also may wish to be sure your data roaming is off.
