ring tones
  • 7
  • Idea
  • Not Planned
I think koodo should have its own app where you can download songs instead of having to steal from those other mainstream apps and it can go on phone bill.
Photo of Misguided Self
Misguided Self
  • 258 Points 250 badge 2x thumb
Posted 6 years ago
  • 7
Photo of Bailey Abrams
Bailey Abrams
  • 436 Points 250 badge 2x thumb
you could always find a usb cord that fits your phone type. And plug it into your computer, and select " USB DRIVE". And then just open your music folder on your phone. and drag music from your computer onto your phone.
Photo of bob
bob
  • 974 Points 500 badge 2x thumb
LIKE
Photo of Denise Purcell
Denise Purcell
  • 102 Points 100 badge 2x thumb
i use Zedge which you can get through the store on your phone it will be under free apps... for zedge and then you can download ringtones, live wallpapers,notification tones and games i believe.. best thing ever that i have used.
Zedge is a great app to download from the Google Play store. You can download ringtones straight to your phone and it's free! However, if you have an iPhone, you will need to download the ringtones on your computer, drag them to your iTunes, and import them into your phone from their. Pain in the ass? Definitely, but it is worth it in the long run. Hope this helped! :)
Photo of MatB
MatB
  • 32,458 Points 20k badge 2x thumb
Or you may try http://www.jamster.ca/ to download unlimited Ringtones, Mobile Games, Cell Phone Wallpaper, Ringtone
Photo of MykeC
MykeC
  • 20,174 Points 20k badge 2x thumb
Hey Mat, let's remember to include that Jamster is a 3rd party service and does require a monthly subscription fee for it's use :).
There are many programs you can download, or use for free online, that allow you to take any MP3 file you already have, and customize it into a ring tone of your liking.
It is very easy to do.
Ring tones are a big thing on the app store right now, but I believe the best option is to start from your own music library. If you already have a song you want as a ring tone, it is much easier to make it yourself and save the hassle of finding an app, and an appropriate version of the song you want.
Photo of RedMageX
RedMageX
  • 2,908 Points 2k badge 2x thumb
Unless you're on a closed OS like iOS, you shouldn't need to pay for.ringtones. Android apps like Zedge is your best bet, or make your own MP3 ringtones on your computer and transfer to your phone over USB.
Photo of Cast
Cast
  • 12,740 Points 10k badge 2x thumb
Don't see the point in your response as Zedge is already mentioned...
Photo of Lynn Micallef
Lynn Micallef
is there a data for ring tones????
Photo of Daniel Kim
Daniel Kim, Mobile Master
Hi Lynn, could you specify a bit more. I'm not too sure what your question is. Thanks :)
Ring tones don't use data if that's what you meant. The only time is when you use data to download a ring tone.
Lynn Micallef
okay that's what I thought some one told me its 50 MG a day for Ringtones... is that true , sorry for misunderstanding question, I didn't know how to word it..
Lynn Micallef
I have Iphone and some one told me its was 50mg bits for having a Ringtone.. now if I buy like 20 dollar visa and buy it and how much is it for d/l one ringtone of Data that I am using..or can I make my own if so how?
Photo of Daniel Kim
You can download ringtones over wifi which is what I recommend. When you click on the ringtone it should say the size of the file so you can figure out how much data it would use based on that. Here is a link for making your own ring tone http://www.digitaltrends.com/mobile/h... there could also be other apps for making custom ringtones
Lynn Micallef
thanks i will give it a try
