Required new phone when upgrading my plan? I want to keep my phone!
Why can't I change my phone plan on-line without buying a new phone? I want to upgrade to the $45 plan but keep my current phone.
Photo of Devon Hutchinson MacDonald
  • 132 Points 100 badge 2x thumb
  • Pissed!
Posted 3 years ago
Photo of Robert
Robert, Mobile Master
  • 103,784 Points 100k badge 2x thumb
Hello Devon.
What does it say? If you're on the old "tab" and your tab contribution is stil 10% instead of 15% this may explain this issue!
Okay, my tab contribution is at 10%, but I have $150 on my tab. What does the 10% have to do with it?
Is that something I can change so I can get a new plan?
Photo of Robert
There's been some changes since the last time you changed your plan. I think you would need to visit a store in order to do what you want to do without buying a phone.
Becasue he tab system has changed from 150 only to 150, 300 or 500$ a new phone is required to take advatanges of those plans "online". Because it is set up like that. Try giving Koodo a call and see what they have to say about this.
Dial *611 from your cellphone or
Here are a list of option available to you
I put the new plan into my cart. Then proceed to check out and it says that I have to add a phone. Says it's required.
Photo of RudyW
RudyW
That's the problem! You are trying to go through as if you were buying or upgrading. You need to be logged into self serve then scroll down and you will see a bunch of links. Click on 'Plans and Add-ons'.
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
Oooops, that's right Rudy. I can scroll down to see more choices.
I was logged in(I believe OP too) but I clicked on "Shop" on top of the page ;P That's why we couldn't upgrade.
Now I know :)
It doesn't go through and then a highlighted message says "Required: Choose a Phone."
I love my phone! :(
Photo of Mayumi
  • 112,744 Points 100k badge 2x thumb
Yes. You can change your plan without buying a new phone through self serve.
Log in self serve > Plan &Add-ons > pick a plan you want
Doesn't work. Tried in the new website too and it won't let me go further until I add a new phone. Whyyyyy????
Photo of Mayumi
Ok. I tried to change my plan. I know what you means now.
I would call customer service to change it. Make sure you tell them you tried through self serve, but it doesn't change without purchasing a phone.
And I'll make sure they don't charge you for this.
They upgraded their site recently, so this might be the reason. Ill let them know.
Thanks Mayumi!!! I wanted to call but didn't want them to charge me for the call. Appreciate your help and Robert's.
Photo of Mayumi
Don't forget mention to them you tried through self serve and it didn't let you change. :)
Yep, he's trying to change his plan now just to make sure it's not a larger issue on the site. He's waiving the fee! thanks again!
