Removing Pay-Per-Use Intl Long Distance
  • Updated 11 months ago
If I remove Pay-Per-Use Intl Long Distance then will I only be able to make/recieve calls in Canada
Photo of JohnC
JohnC
  • 1,724 Points 1k badge 2x thumb
Posted 11 months ago
Photo of Goran
Goran, Mobile Master
  • 97,238 Points 50k badge 2x thumb
I can't remember if the US needs it as well but otherwise that's correct. You can also take out your Sim, or keep your phone in airplane mode to not send / receive calls.
Photo of JohnC
JohnC
Ok. There's been a few accidental calls to the US and I want to stop that. Hopefully that'll do the trick. Still want Canada wide calling.
Photo of Mayumi
Mayumi, Mobile Master
  • 113,730 Points 100k badge 2x thumb
If you mean that you want to disable to call USA while you are in Canada, then I don't think removing PPU ILong Distance will help.
If you dial unknown area code, you should check it before making calls to prevent accidental ILD charges.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 141,522 Points 100k badge 2x thumb
Mayumi is correct. Removing PPU int'l long distance will only stop you from calling numbers which require an international dialling prefix. You will still be able to call any number within the North American Numbering Plan, which covers: Canada, United States including its territories (American Samoa, Guam, Northern Mariana Islands, Puerto Rico and United States Virgin Islands), Bermuda and many Caribbean nations, including Anguilla, Antigua and Barbuda, Bahamas, Barbados, British Virgin Islands, Cayman Islands, Dominica, Dominican Republic, Grenada, Jamaica, Turks and Caicos Islands, Montserrat, Saint Kitts and Nevis, Saint Lucia, Saint Vincent and the Grenadines, Sint Maarten, Trinidad and Tobago.
Photo of JohnC
JohnC
Oh. Ok. So how do I disable sending/receiving US calls from the self serve?
  • 140,522 Points 100k badge 2x thumb
The short answer is that you can't. There may be an app available which would allow you to do so, but I have no idea which one(s) would work for you.
Photo of Mayumi
  • 112,972 Points 100k badge 2x thumb
@ John
There is no long distance charge for receiving calls from USA/ International at least.
It still use your minutes if you don't have unlimited minutes tho.
Photo of Mihaela Nistor
Mihaela Nistor
removing that feature of your account will not guarantee the stop of the accidental calls to Us
