Receiving Call from Canada is there a charge when I'm outside Canada?
I'm from Canada but working in Nigeria right now, i have unlimited incoming calls in my plan. Is there a charge if my wife call me from Canada?
Photo of Rodel
Rodel
Posted 3 years ago
Photo of Jonathan I
Jonathan I, Mobile Master
Yes. It doesn't matter if you have unlimited calls on your plan because you're outside of Canada. The calls don't cost minutes but you are roaming and using someone else's network so it's going to cost you either $1.50 or $2.50/minute! I suggest unlocking your phone if you can and using a SIM from a Nigerian provider or buying a cheap phone there in the mean time.
Photo of Rodel
Rodel
Thanks I will put my phone on vacation mode, until i comeback to Canada.
Photo of Dennis
Dennis, Mobile Master
  • 195,300 Points 100k badge 2x thumb
Dear Nigerian Prince,
Note that if you put your phone on seasonal hold, that when you come back you have to choose an current in-market plan, so you may not get your plan back if it is not available anymore.
Photo of Rodel
Rodel
I completely understand that when I said that I'm going to put my phone in vacation mode, no need to emphasize.
Photo of Dennis
Just so if anyone else had a similar question and they read this they would know too
Photo of BobTheElectrician
BobTheElectrician
  • 67,528 Points 50k badge 2x thumb
You will have serious roaming charges.
http://help.koodomobile.com/coverage-long-distance-and-travelling/travelling
If you are at all talkative, best to investigate getting a local SIM or calling card.
Incoming texts are free, if you do activate roaming,  so you can call back using a cheaper alternative like VoIP. Check out Fongo, do a google search for international voip.
Photo of Rodel
Rodel
Thanks, I already downloaded Fongo.
But then, yo guys never satisfactorily answered his question. He wants to know the cost implication of receiving calls on his koodo line in Nigeria, not the cost of using it to make calls to Canada from Nigeria. Thanks
Photo of David
David, Mobile Master
  • 91,840 Points 50k badge 2x thumb
Costs the same either way.
