Re Home Phone Hub: the red lights are flashing. There was no SIM card in the box. was it already inserted in the hub?
  • Updated 4 months ago
flashing red lights
Photo of Barbara Ettles Carter
Posted 5 months ago
Photo of Dinh
Dinh, Mobile Master
  • 32,872 Points 20k badge 2x thumb
Hi,
I don't think it was already inserted in the box. You had to insert yourself.
There is 4 LED lights on that HUB, which one was flashing? If the SIM light was flashing, and there was no SIM with the box, I would definitely check the SIM slot and see anything there.
I will look again - my vision is not great for close up - awaiting cataract surgery - thank you.
Photo of Dinh
Dinh, Mobile Master
Oh, I hope everything is fine for you.
I would suggest you check the box again and see if a SIM was included. Also try to unplug the device and plug it again and see if could help.
Photo of Charles Yorston
Charles Yorston
  • 80 Points 75 badge 2x thumb
Mine was attached to the paper that was folded in half that came with the phone
