Rate for roaming in USA calling Hong Kong number
This conversation is no longer open for comments or replies and is no longer visible to community members. The community moderator provided the following reason for archiving: roaming add-on
Under the $35 LIGHTWEIGHT CANADA-WIDE PLAN. What is the rate for calling a Hong Kong number while roaming in the USA?
Photo of Amy Tsui
Amy Tsui
  • 80 Points 75 badge 2x thumb
Posted 3 years ago
Photo of Curtis
Curtis
  • 1,330 Points 1k badge 2x thumb
Hi Amy,
If you call overseas while in the USA, you combine the roaming and international long distance rates.
Without a roaming add-on, calls cost $1.50/min (http://koo.do/Im7Mcg) while long distance to Hong Kong is $0.50/min (http://koo.do/JALDeg). So, while roaming, calls to Hong Kong will cost $2/min.
You can check out that first link for roaming plans to cover you while in the USA.
________________________
Photo of Amy Tsui
Amy Tsui
Can i confirm that if i purchase a 3 days $20 unlimited Talk and Text roaming add-on... that it will be $20 one-time fee. And then $0.50/min calls to Hong Kong.
Does this apply for both incoming and outgoing calls to and from Hong Kong
Photo of Mayumi
Mayumi, Mobile Master
  • 112,704 Points 100k badge 2x thumb
Those "Unlimited Talk and Text US roaming add-on" Includes calls within the U.S. and to Canada only.
Photo of Curtis
Curtis
Thanks for getting back to us, Amy.
The $20 roaming add-on will cover you for the roaming fees. You'll still be charged $0.50/min to call out to Hong Kong.
Incoming calls, on the other hand, won't count as international long distance. So you won't be charged long distance fees to receive calls.
And once the 3-day period ends the roaming add-on is gone. It won't renew unless you want it to.
