Questions about booster add on (adding minutes) buying a higher $ amount top up voucher
I signed up with prepaid a few days ago. My base plan is $15.00 for unlimited texting. My booster is $10.00 for 100 minutes. From my understanding the base plan needs to be renewed every 30 days. The boosters don't expire until you use up your minutes or obviously if they are low enough you need to add more.
My question is.. For the $10 booster will I be able to choose a higher dollar amount whether top up card or pay by credit card on the Koodo website? For example the top up amounts are $10, $25 etc. So if I choose a higher amount does that mean I
will have extra voice minutes on my account? I'm not sure how it works.
Photo of shelley
  • 2,884 Points 2k badge 2x thumb
Photo of Paul Deschamps
Paul Deschamps, Mobile Master
  • 193,128 Points 100k badge 2x thumb
Yes the boosters can be stacked so the amount of data or minutes willjjust continue to accumulate.
