Questions about my phone in Cuba
  • Updated 1 year ago
I am heading to Cuba and noticed Koodo offers an "outside of US" travelling plan. Is there anything I need to do to my phone after I've texted for the 30 day plan? Or is my phone ok to leave as is while in Cuba (meaning, should it be on Airplane mode, etc)? I only need to receive and send texts (in an Emergency).
Thanks!
Photo of Katelyn Murnaghan
Katelyn Murnaghan
Posted 1 year ago
Photo of titaniumtux
titaniumtux
  • 12,952 Points 10k badge 2x thumb
The only steps involved are to enable roaming as a $0 add-on through self-serve, then texting or activating via self-serve the roaming plan (which you have already done). Texts will not work while on airplane mode. By default, most phones disable data roaming (just make sure it's disabled in settings). Don't take phone calls, and don't make any (good discipline) while roaming and you'll be good to go.
Bon voyage!
Photo of Allan
Allan, Mobile Master
  • 62,804 Points 50k badge 2x thumb
Also a friendly reminder to not go over your data as roaming charges for data in cuba are $10/MB
