Question re: plan
I just changed my plan to the CAN data 500MB + min BB $50. Does this give me access to the internet from my phone? How can I send and receive picture messages?
Photo of Shannon St Pierre
Shannon St Pierre
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
Yes it gives you internet access from your phone.
To send picture messages, first make sure you can access the internet (i.e open a webpage). Assuming that does work normally, sending picture messages is just like sending regular texts. There is a small paperclip icon on the texting app. Tap on this and it will give you the option to attach a file/picture/video/etc.
Shannon St Pierre
Ok, when I tried to access the internet it does my plan does not support this. Also I do not have the paperclip icon. My phone is the Blacberry Curve.
Thanks
Photo of Zaphod Beeblebrox
Zaphod Beeblebrox
  • 50,798 Points 50k badge 2x thumb
Try this...
Go to Options > Device > Advanced System Settings > Host Routing Table.
No matter what is seen or not seen, press the Blackberry button on the phone (menu button) and select Register Now. Power down the phone for a minute the turn it on. You should get a response about "your device is successfully registered on the wireless network" or something like that. When that happens, make sure data is on and try to browse.
Shannon St Pierre
I feel like I'm really stupid right now!! Where am I finding options?
Zaphod Beeblebrox
When you bring up all the apps on your phone, Options would have a symbol that looks like a wrech :)
Shannon St Pierre
ok, nevermind I figured that out...nothing shows up. It says no entries
Shannon St Pierre
and by nevermind I mean I found the options>device>advanced system setting and host routing table but like I said, it says no entries so I can't select anything
From the host routing table page, press the menu button (the one with all the dots). Then click on register now. Click ok. Then restart the phone.
