Question regarding roaming bill
  • Updated 11 months ago
Hello, recently i bought a Roaming add-on while travelling to the US. Now, i need to see the bill BEFORE my period is over for my employer. Is there any way to do so?
Regards
Photo of Brandon Jimenez
Brandon Jimenez
Posted 11 months ago
Photo of Bernard
Bernard, Official Rep
  • 80,800 Points 50k badge 2x thumb
@ Brandon You bought the $40 add-on which comes with unl minutes and text. So you will not have to worry about overages on that. There is 250mb data included in that pack. You can certainly log into your account online and check your data use. Just click on the image and you will see it broken down on a daily basis. Then just match it against the days you were gone.
