Question on Anytime minutes in $29 Plan with Upto 100 min Anytime
hello. i took the $29 plan yesterday. I see that the long distance calls are deducted from the anytime minutes. How do I know if I am calling a long distance number? Since in the same province, I suspect there are long distance charges. thanks for the help.
Photo of rmp963 .
rmp963 .
  • 80 Points 75 badge 2x thumb
Photo of Dennis
Dennis, Mobile Master
  • 196,284 Points 100k badge 2x thumb
All calls not made during the evening and weekends are deducted from your anytime minutes (local, canada, international)
Photo of Andy Zhong
Andy Zhong
  • 846 Points 500 badge 2x thumb
The 29$ plan includes Canada wide, so if ur calling during the day time it does towards ur day time minutes. If ur making long distance calls there will b long distance chargers and it uses ur day time minutes if ur calling in the day. If ur calling after 5pm or weekends to someone outside of Canada, ull only b charged for the long distance and it won't use up ur day time minutes
Photo of Mayumi
Mayumi, Mobile Master
  • 115,066 Points 100k badge 2x thumb
Long distance within Canada - No long distance charges
Long distance outside Canada - International rate
Photo of Daniel Gunn
Daniel Gunn
  • 19,800 Points 10k badge 2x thumb
If the calls are made in Canada to a Canadian number you are not charged long distance no matter when you make a call, the only thing that happens is it uses your day time minutes during the day. During your nights and weekends you can call all you want, as long as the call is in Canada to a Canadian number. If you make a call to outside of Canada (US, international) then you will see extra charges. The current charge for calling to the US (no matter what time of day) is $0.50/minute.
Photo of Dennis
  • 196,274 Points 100k badge 2x thumb
Basically long distance charges are independent of your anytime minutes.
If you call the US during a Monday at noon u will get dinged with the 50 cents per min Gunn said, plus it will use your anytime mins
Photo of rmp963 .
rmp963 .
Thanks for all your replies. I was a bit confused that during the weekend and after 5 PM all calls Canada wide it will still take my available airtime minutes. Thanks for the clarification
