programs stopping issue
I have a samsumg galaxy sii and just started having problems with it yesterday. It started with my sms backup app stopping, then google apps stopped working so I shut the phone off for 12 hrs, turned it back on this morning and the same thing happened. Is anyone else having these problems
Photo of Sue Lowen
Sue Lowen
  • 300 Points 250 badge 2x thumb
How's your memory situation? When android starts running low on ram, it starts shutting down programs. If any of the programs it's shutting down has an option to put an icon on your notification bar, use it. Doing so will prevent android from closing the app.
If you're using a task killer, try white listing the apps so they won't be closed.
What apps specifically are you using that's closing ?
Photo of Sue Lowen
Sue Lowen
Hi chad..everything you just said is foreign to me..lol..sorry..I have been using sms back up by christopher studer for over a year and never had any issues, the google apps are the red google+ app and the blue google icon...
Photo of Sue Lowen
Sue Lowen
My memory situation is good...according to kies I am at 5.13gb of 11gb
So that's actually your storage memory, I'm talking about ram.
Look for things in your program settings like "make persistant".
Navigate to settings...apps...running
There is a graph on the bottom that shows how much ram is left, and how much is being used.
Photo of Sue Lowen
Sue Lowen
in my app manager i have in my show cached processes 574mb used and 209mb free, and under the all tab i have 0.95gb used of 1.0gb free
Try going through and deleting apps you dont normally use.
Photo of Sue Lowen
Sue Lowen
I have plenty of room on my sd card 6.1GB, how do I move things from internal memory over to sd card? Also How do I stop programs that I am not using from running
Photo of Sue Lowen
Sue Lowen
I will try that and get back to you if that doesn't work. I deleted a bunch of pics and text messages yesterday. Gotta finish my shopping so I will do it later, thank you for the help and if I have any more questions I will reply.. Merry Christmas
That's good, but it's really about what's running and not what you're storing. Going through the list of what's running and determining if that's an app you actually want to use anymore is more important. And this may not end your issue although it will help your device run a bit faster.
