Problems with Data Booster Add-On
  • 2
I've just started using Koodo and I bought a $10 Data Booster Add-On as part of the plan. However, I can't seem to use any data on my phone. Has anyone else had this problem? How did you solve it? Thanks!
Photo of Lucy Hall-Patch
Lucy Hall-Patch
  • 92 Points 75 badge 2x thumb
  • 2
Photo of Jonathan I
Jonathan I, Mobile Master
Generally speaking, you need to make sure data is turned on and you have the correct APN settings in your device if it's not originally a Koodo phone:
APN: sp.koodo.com
Proxy server: 74.49.0.18
Port: 80
Username:
Password:
Server:
MMSC: http://aliasredirect.net/proxy/koodo/...
Port: 80
MCC : 302
MNC : 220
APN type: leave blank, or try "*", "default", "internet", or "default,mms"
It would be easier to assist if we knew what kind of phone you have. Model # would be especially helpful.
Lucy Hall-Patch
I just tried your suggestion and it worked perfectly. Thank you so much!
