Problems using Blackberry Z10 link software to sync pictures
I have problem with blackberry 10 link.
My desktop uses Win 8, and I have AVG with a firewall. When I connect Z10 by USB, I can see my device in the Network part of win explorer, but can not expand it, nor I can sync anything from it. Backup works though. When I try to "mound" Z10 drive. it fails with x40 error. When I try to use link by WiFi, I constantly get connection errors, but my Z10 is definitely connected. In BB link I can see my device, just can not sync. I turned off AV, run link as admin, made changes to usb hub settings so power savings can not turn them off, and not sure what else to do. Link is the newest, Z10 OS is the newest, ... Maybe the fact that my local computer IP is static can have something to do with it. My local IP is 192.168.... end Z10 over WiFi has 192.168.... address, while over usb will have 164.... My router assigns addresses in range of 192.168....
Would appreciate any help as this is like working with a virus :( It does everything but what it should!
Photo of hikerVancouver
hikerVancouver
  • 132 Points 100 badge 2x thumb
  • sad
Photo of Danno
Danno
  • 810 Points 500 badge 2x thumb
Bump to keep this on page one - not many Z10 users here yet.
Photo of Ivan
Ivan, Mobile Master
What gives you the X40 error? Windows? BB Link? AVG? Firewall?
I've noticed that my Z10 doesn't want to mount with just any micro-USB cable either.
hikerVancouver
The error comes in the small pop up from BlackBerry Link. There was an error 0x80073075 network path not found ad well.
I think the issue is in the auto settings BlackBerry assumes. At work I managed without any problems to install and use link. The only difference is that at work this is done on Internet station, which is not part of the network. All settings are auto. At home I use static IPs, for routing purpose. It seems that many people have the same problem, as I have seen lot of similar complaints on BlackBerry Link website.
Photo of Nicoleta Chirila
Nicoleta Chirila
  • 60 Points
hello i have the same problem with my z10
on blink i read my pin but the window pc write that my bb is not connect
no beckup
no photos sync
nothing!!
please help me
Photo of mattjs
mattjs
  • 15,658 Points 10k badge 2x thumb
Do you have mass storage enabled in settings? Do you have Connect through USB selected in Storage and Access? Are you trying to Access through Wifi? Is this enabled on your device as well?
hikerVancouver
Wifi works the same, it doesn't.
Mattjs your comments made me think, but I think they apply to older version of blackberry phone, unless I am missing something.
Photo of mattjs
mattjs
I have a z10, I access link over wifi. Try and enable file sharing via wifi and connect to link, you should be able to do this..
hikerVancouver
Mattjs, thank you!
You are correct!
I have enabled WiFi adapter, connected desktop to my WiFi network, and I could access Z10 in Win Explorer, where I copied files from it to my desktop. Sync functionality inside link still didn't appear to be working but I was able to access files, what is the most important.
I hope BlackBerry makes changes to their link software soon though.
hikerVancouver
Just reminder to anybody who tries this, after getting pictures, disconnect desktop from your WiFi, and disable WiFi adapter, if it does disable your ethernet adapter, otherwise you will stay on slower WiFi network.
hikerVancouver
The issue I see with this is that Windows sees Z10 as a Media Server, so no documents in those folders.
hikerVancouver
Another update -- make sure you get latest firmware update for your router.
I use D-link DIR-655, and after updating router firmware, there are no problems connecting to Z10 !!!
