Having problems sending texts
  • (Edited)
Having Problems sending texts. When I send it just hangs. Will not go. Have to POWER down phone and restart before it will go. Something wrong with Sim card ?????
Photo of Paul VanLingen
Paul VanLingen
Photo of John Burke
John Burke, Mobile Master
What's your phone?
If it's a CDMA you can call Koodo & have them "Clear your Switch" (they'll know what you mean).
If it's not a CDMA though, try powering down, removing the batter & SM, waiting 5minutes then put it back together & powering back on.
Photo of Timo Tuokkola
Timo Tuokkola, Mobile Master
  • 139,982 Points 100k badge 2x thumb
If restarting the phone gets the texts working again then odds are you are correct and the sim is failing. The text messaging centre number is stored on the sim and gets re-downloaded every time the phone connects to the network again. If it keeps hanging the sim is likely not retaining the number the way it should.
