Problems connecting to wifi!!
My galaxy S2X wont connect to wifi.. My wifi is working fine on my laptop an ipod? I never had this problem before...I reset my router yet it is still not working..help please :(
Photo of Ashvin Locham
Ashvin Locham
  • 92 Points 75 badge 2x thumb
Photo of MatB
MatB
  • 32,458 Points 20k badge 2x thumb
Try Wi Fi reset, dial *#*#526#*#*
If you tried Wi-Fi reset and not working, use 3G connection and download Wi Fi Fix apps from “Google play” , This apps is intended to fix any issue with Android phones Wi-Fi issues.
Photo of Get it solved !
Get it solved !
  • 4,044 Points 4k badge 2x thumb
Is your phone connecting to the router but no internet or it is not connecting at all ? Also, is your router new or old ?
Photo of Steve
Steve
  • 4,030 Points 4k badge 2x thumb
I don't find the stock Android Wifi management adequate if you are connecting to more than one network so I use an app called "Wifi Manager" and thereafter all my problems have gone away, so you might give that a try and see if it helps. At least it tells you what is going on (i.e. what the Wifi is trying to do right now, etc.). You can always uninstall it if you don't find it helpful but I couldn't live without it :)
Ashvin Locham
Its not connecting at all... It normally connects automatically... The name shows up but it says not in range when i am exactly right beside the router... :(
Get it solved !
So it was working fine with the same phone and same router ? If so you have to backup your data and then do a reset to factory settings. it should fix your problem
Photo of MykeC
MykeC
  • 20,174 Points 20k badge 2x thumb
Hey Ashvin, I also suggest contacting your ISP for assistance with your Wifi connection issue. If they can't get it to work then it may be an issue with the phone. At that point, it would go under our warranty.
________________________
Ashvin Locham
Well I am not in the country till the end of August...I am on summer break holidays...i brought the phone along with me...so now how do i go about contacting my ISP? is there anything i can do online to get this fixed? Please help? Is the warranty word wide? Can I get it fixed at any Samsung store over here?
